XG850 Starter replacement
5,586
curious., here in Canada base price is $20K, so US$ maybe $15K ? Tossing $1,000 US$ into a 15k has to HURT unless it was say 20 years old.....well used...
jaxs
B1750HST
Jun 22, 2023
904
683
The problem I have is really on Kubota. The kit I just purchased with the solenoid/relay and the replacement wire's no way should cost that much. The solenoid is the most expensive in the kit and there is not way it should be more than $100. Even OEM. I'm pretty disappointed in Kubota. Wish I knew the warranty ran out in 2023. This sidekick is a POS. The worst Kubota product I've seen yet.
As it should be since it's typical mo. Kit fits 10 models. If you had access to Kubota's warehouse I wager the same relay can be found in dozens boxes with various cables and bareing different part #s. A less technical example more folks might identify with is paint. Kubota's colors really show with their paint (pun intended) 😁 The difference in price with 90% of mfgrs who release color code is staggering. A Kubota owner's blood must be a special shade of orange to believe their paint is worth 3x others because it has secret sauce in it.
Right you are again.
After looking at the kit on Messick's site I'm certain I can buy everything needed at the local auto parts store for less than $100. As you said about most expensive part in kit is relay and I recently replaced one on a Ford E350 Powerstroke for $38. If a relay has the ump to crank that beast I'm pretty sure it's up to this task. This thread is old but if the member who said they have 3 of these machines should start now to get help figuring out what to buy if they can't figure it out for themselves when one fails.
