Which SSQA adaptor do I need..??
3,100
I have a Kubota LA-1002 pin-on loader…which uses 1-3/16” pins. and I use it with pin-on attachments…. by using a specially mfr’d adaptor which allows me to pick up pin-on attachments very easily. (I’ve posted about this in other threads, I’ll try to post again the link after I edit this post.) Here’s the type pin-on adaptor I bought and which I still plan to use even with the universal SSQA adaptor I’ll buy.… Yes, I know it’ll place the implement a bit further out reducing lift-capacity…but I can also not use the pin-on adaptor if that ever becomes a problem.)
I do not have any SSQA attachments at the moment …and frankly do not know that I’ll ever need anything other than what I already have…a Kubota bucket and pallet forks made by the Washburn/Hayspear folks I’m posting about later in this post…. BUT…I’d like to go ahead and gift myself a universal SSQA adaptor to fit my pin-on loader (w/the adaptors already mentioned) to a universal SSQA …in case I later want to buy or borrow a SSQA attachment.
What I don’t know is…. which of these two offerings below is the one I should purchase…..as I do not know the difference between the “older” 8296 and the 8297 types: https://hayspear.com/skid-steer-hitch-conversion-adjustable-mounting-widths-3-rollback-settings
5,321
I personally think your going about this backwards.
You would keep the implement closer if you got a stock direct attach SSQA adapter then added a pin on adapter to that.
