Which one do I have
Wideopen38
21
SUMMERVILLE
Which hydraulic valve do I have open or close center. Its only a lb2500 Kubota with a lb400 loader on the front.I bought a open center valve put I can't get the rear lift To go up now.
Captain13
Feb 27, 2019
516
168
Kathleen, GA
I believe these are open center valves which means that flow goes through the valve and back to the reservoir when the valve is in neutral. When activated, instead of the fluid going to the reservoir, it goes to whatever is being hydraulically driven. Usually with open center, the valves are all in series allowing for any valve to be activated at any time.
Closed center is usually used on high performance systems so when in the neutral position, the fluid doesn't go to the reservoir but to an accumulator.
Check the screw knob under your seat and make sure it hasn't been closed off.
5,124
All Kubota's use Open center valves.
Go look at your other thread, as I've found your problem.
