WHAT OIL FOR Z700 TRANS OTHER THAN KUBOTA TRANS OIL ??
Sidekick
Jul 29, 2023
859
1,013
N.Y,
My Z726 drives call for the Parker oil that is like 30 bucks a quart. Dealer said for warranty it should be used at the required drain intervals. It is going to be expensive with a couple gallons a side.
Smokeydog
Jun 2, 2020
733
691
knoxville, Tennessee
Yes, no, maybe. Hot topic.
Kubota trans/hyd oil is always a safe bet especially for hst and often the cheapest option. Mail order from Messicks or Coleman. Buy enough from dealer to keep on hand. Not likely to go bad. Good to have filters, oils handy for next service.
2,731
I like the question now ........... is it safe?
So - yes there are other "oils" out there - some people here have used others, but - did I say but? I would NOT go to wallyworld or TSC and pick up a 5 gallon container of "meets kubota's udt specs" .
I really would consider ordering some oil from messicks or colemans equipment. Yes shipping sucks to pay on heavy containers - so order twice as much and have it on hand when ready to change it again.
Sidekick
Jul 29, 2023
859
1,013
N.Y,
My Z726 and I think all 700 series have the Parker HTG14 transmissions and they require Parker OEM oil for the best life and warranty coverage I was told by my dealership. Put anything else in them and it could cost you over 3k a side if there are problems. Good oil is a cheap price to pay with the cost of parts and labor these days.
4,802
My Z726 and I think all 700 series have the Parker HTG24 transmissions and they require Parker OEM oil for the best life and warranty coverage I was told by my dealership. Put anything else in them and it could cost you over 3k a side if there are problems. Good iol is a cheap price to pay with the cost of parts and labor these days.
Is that Parker HT 1000? If so the datasheet is remarkably unremarkable:
  1. Group II base oil
  2. KV100: 13.2 cSt
  3. KV40: 126 cSt
  4. Viscosity Index: 99
  5. Pour point -11F
A conventional monograde ISO 120 hydraulic oil.
cthomas
LX2610 HSDC
Jan 1, 2017
843
557
La Farge Wi
How long do you want the transmission to last? If the dealership is far away, make it a yearly trip or just pay for shipping.
Sidekick
Jul 29, 2023
859
1,013
N.Y,
  2. KV100: 13.2 cSt
  3. KV40: 126 cSt
  5. Pour point -11F
Yes HT 1000 is the specified oil along with the filter changes. First change at 250 hours. I was told it has special additives for the Parker drives. I know nothing about the specs and only use what is recommended in the equipment I buy and only post what is recommended online when someone asks.
Fordtech86
L3200
Aug 7, 2018
4,966
5,915
Pineville,LA
If the mower in question has Parker drives, here is from the manual.
Have the Parker drives in my non kubota zero turn.
4,802
I made the comment that the HT 1000 data sheet was unremarkable. In fact it is remarkable in one regard - HT 1000 does not conform to any ISO viscosity grade. It is dead in the middle of ISO 100 and ISO 150. There is no official ISO 120 grade.
The alternative Shell TTF-SB oil in the manual is in fact an ISO 100 grade oil.
Can't comment on Parker's claim of extended (4X) OCI with HT 1000. That would take more than a couple extra points on viscosity.
Fordtech86
L3200
Aug 7, 2018
4,966
5,915
Pineville,LA
Thanks Dan! I only posted that because I remembered when I did mine that the HT 1000 wasn’t the only fluid Parker showed. (Not sure if the OPs mower even has Parker drives,didn’t look that far)
lugbolt
ZG127S-54
Oct 15, 2015
5,393
2,083
Mid, South, USA
Not sure you can go wrong with what the book says....
but whatever. Lubricants always start a forum war, so that's all I'm gonna say about it.
4,802
Perhaps butter or vegetable oil should be used?
Pardon my rant but....
Perhaps OEMs should start being honest and these discussions could be a little more reasoned and fact based and reduce the hyperbole level. There are good solid performance based standards and metrics that they can cite if they wanted to:
But that would make it hard to justify the name brand FUD they spout and enable owners and operators to make fact based choices. Third party lubricant manufacturers have no problem giving you real perfomance data and industry standard specifications.
lugbolt
ZG127S-54
Oct 15, 2015
5,393
2,083
Mid, South, USA
I was at a manufacturer's dealer training (optional training) session, which lasted 8 days (!), we studied lubricants. Not all of it dealt with engine oils, it dealt with certain fluids used in transmissions and gearcases and such in addition. Majority of it dealt with ATV and motorcycle stuff BUT the principles apply to all lubricating fluids. This was an eye-opening class.
Basically a manufacturer can give all the ISO specs, however the vast majority of people wouldn't understand it. MSDS and ISO spec sheets give a lot of information but manufacturers are not required by federal law to give exact specifications or formulations and they never do. Reason being, keeping it short, trade secrets. The actual additive packages that different manufacturers use are often guarded heavily. There were about 80 of us in this class and every single one of us was asked to not disclose some information. And I'm not, I've stuck with that.
Another tidbit. The fluids are often formulated at the same plant that other fluids are formulated at. For instance, let's use PS-4 from Polaris. It may be made at the exact same plant as, using another example, Valvoline (since it's a well-known name). But, we have to keep in mind that PS-4 is made specifically for Polaris equipment, using an additive package that only Polaris engineers and the fluid manufacturer knows about, and it comes out the same door as the cheap $5/quart stuff that you can but at wal-mart. But just because it came out the same door don't mean it's the same stuff, and often it isn't. This was a huge issue with motorcycles that used a wet clutch, where guys were buying Rotalla T6 because even though T6 is expensive, it's still cheaper than Yamalube. Guys with the early R1's were destroying engines. Basically T6 excludes a certain additive that Yamalube has, which helps the wet clutch live. Over time, Rotella does not protect the clutch and the lining gets burnt, it delaminates from the backing, falls down into the pan and plugs up the pickup screen-which usually destroys the engine. I did a number of them before Yamaha was able to put their finger on the problem. We are talking about 2003-ish through 2007 or so. Of course the engine was completely changed in 2009, to a different design, and by then also the owners were starting to understand the issues. Some still didn't care, and that's fine, as I still built a few engines once in a while. They paid my bills, although the early units were great for us techs. Same for the Kawasaki VN1500's eating clutch springs, due to owner neglect and sometimes abuse. There is more to it as to why, but lubricants played a role. If people would use what's recommended and go by the book, lubricant-related failures are drastically reduced. And even better, when a factory rep asks for a fluid analyses, the analysts and the factory reps want to see certain things. If it ain't there or ain't what they want to see, they don't like it any. If it is, and it's documented that you used what's recommended, it becomes an easier process. MUCH easier in my experience. Warranty stuff can be a real bear. And, people often refer back to a certain court decision that suppsedly protects people and manufacturers, as the end-all, but in fact it's not. There is enough vagueness in that set of rulings that it may not help you. You cannot go wrong with OEM stuff. It may cost a little more but that peace of mind is worth the extra cost, at least in my opinion-and my experience.
