mdhughes
L3901DT
Dec 10, 2014
1,216
636
Ste Geneveive county, MO
Put the grapple on the L3901DT and move a couple 80" logs from a Blonded Ash that I cut down a couple of weeks ago. It's a little muddy here and had a little fun getting out of the area that the logs were. Blocked the logs up and got them split and stacked.
I then used the grapple to gather some leaves that I had blown together last month. Moved them down in the woods.
Reactions: 10 users
g_man
Feb 3, 2023
112
495
NE Vermont
Curious - how do you do this with your grapple ?
gg
3,969
Used it as a learning experience for him on fixing a tire in the woods…
There is an easier way to replace the valve stem than taking the tire off the tractor and breaking the tire bead. I had the tire valve stem fail on my water storage tank and there is no way to get into the tank to repair it. I learned about this tool that replaces the valve stem from the outside. You install the valve stem onto the tool, and lubricate the valve stem first with tire lube (dishwashing soap). Next, put the plastic tube over the valve stem hole and push the new valve into the hole using the tube. When I did this job, I pushed the valve stem too far, so I had to hold the valve stem with my fingers and unscrew the tool to get the "funnel" out of the way. Then I put the tool back onto the valve stem and pulled up on the stem until it seated into the hole properly. I think that the reason it went too far into the tank was because I didn't have enough strength in my hands to put the valve stem into the hole, so I used my rubber small dead blow hammer. Took all of 10 minutes including reading the instructions.
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
571
408
central ny
I am having a lot of arthritis and trigger finger problems, I have a weak grip too. But his tool looks like something I might have to have!
I have a handle for pulling in valve stems and an assortment of stems on hand. It is that little funnel thing I lack.
Thanks for posting it.
Bill
rc51stierhoff
B2650, MX6000, (BX sold)
2,268
I like the saw box setting on your ballast box (y)
gg
Thanks. I built the top box a while back (link below)…it slips on and off without any fasteners.
Gary Olson
L2501 w/FEL and grapple, 3pt auger
Mar 10, 2022
105
207
Mark Twain Forest
Cleared out some cedar, hickory, oak, and trash trees. A couple of stands of black walnut have grown; and I am clearing out the competing undergrowth so the black walnut can flourish. Although gooseberry is growing with the black walnut. Trying not to rip those out is challenging.
ken erickson
Nov 21, 2010
1,013
1,582
Waupaca Wisconsin
I see you’re located in the Mark Twain national forest. I had 35 acres off the Berryman rd, north of Hwy 8, west of Potosi, Washington county with two sides bordering the Mark Twain. I now live in Central Wisconsin and think back just How remote my land was in Missouri compared to my land now. Missouri is a beautiful state and I still miss it after 22 years!
Nomore67
Currently own- B2601, LX4020. Previously owned- BX1870, B2601
Apr 28, 2019
17
23
Minnesota
Couple of simple additions to the LX4020... Added a little extra weight to the box blade for more traction, 👍. And, added an ammo box toolbox onto the slow moving vehicle bracket, 👍.
Reactions: 6 users
S-G-R
LX3310, LA535, rear remotes, third function, R14's
Jun 17, 2020
939
1,734
PEI Canada
Nice! What do you think of the tires? R4+?
Nomore67
Apr 28, 2019
17
23
Minnesota
So far I like them. (Still adjusting the PSI down from the super full from the dealer, but they to work pretty well).
I have R14’s on B01 and really like them! We haven’t had any real snow yet to test these new R4’s, I’m hoping with some weight they’ll do great though….
mdhughes
L3901DT
Dec 10, 2014
1,216
636
gg
Open it all the way and tilt the grapple all the way forward, then back drag with the loader in float. Then close the grapple. I don't do this on the grass, just in the woods next to the grass.
If I'm picking up leaves in the grass, I use a blower to make a pile and the just close the grapple over the pile trying not to get into the grass.
