PaulL
2,476
1,391
NZ
today, I sold it!
officially tractor-less for at least the next 14 hours 🤪
No longer matching!! I don't think the LX3310 is available here. And I definitely cannot fit one in my shed, nor do I have enough use for one.
Did you ever manage to adjust the 3ph to start raising at 1 on the lever?
B737
LX3310
Jun 9, 2019
2,024
2,201
No longer matching!! I don't think the LX3310 is available here. And I definitely cannot fit one in my shed. - Did you ever manage to adjust the 3ph to start raising at 1 on the lever?
im a little sad we're no longer twins Paul, but we'll always have our BX and B2601 memories together :LOL:
The dealership said it was operating normally after they looked. It was getting full range up / down, just the way the lever is indexed I think...
If you can fit your B2601 in your shed, the LX3310 will fit :D:devilish:
B737
LX3310
Jun 9, 2019
2,024
2,201
This started about three weeks ago when this perfectly healthy pine tree fell in the pond. Of course most of the limbs were on the pond side where the most light was so they’re underwater and jammed up in the muddy pond bottom.
That was quite a feat NCL!
S-G-R
LX3310
Jun 17, 2020
1,137
2,330
PEI Canada
Took the deck off. Cleaned it and sharpened the blades. Did the 150 hour service on the tractor two hours late. Both front tires appear to be leaking again. Probably got poked with thorns again. I'll go back at my battle with them when the weather cools down.
D
Deleted member 47704
Guest
Put bolt grab hooks on bucket. 40 bux and powder coated orange
Built a tool carrier
Put a 3 point receiver hitch adapter on
Plugged a hitch cargo carrier in
bolted down a 108 qt Plano storage trunk to it
cost total for it was 237.
RichardAaronlx2610
Aug 3, 2021
449
502
New Jersey
Pics?
3,809
flail mower today whacking some weeds. Managed to smoke the belts on the mower with all the stilt grass wrapping up. Ugh. Time to find some spare belts.
On the plus side, I sold one of my quads today. Now, I'll just have to be happy with the wife's grizzly.
D
Guest
I'm working in an area where we had nursery material. I'm clearing out stuff that got rooted in and can't be dug. I need to keep choker cables,chains, loppers and a chainsaw handy. The extra lift capacity of the LX2610 over the B2601 is why I wanted the larger machine.
Trunk is bolted down with some button head screws, large fender washers and nylok nuts.Room around it for chains etc.
Cargo carrier is 48x20. 1 1/4 sq has adapter for 2" receiver. This whole thing is a lightweight set up, its not carrying a lot of weight, otherwise I would have gone heavier (more $$$) Carrier rated for 300 lbs, I think 100 would be the limit. My Makita 14" LXT battery chainsaw, loppers, tow, chains etc probably close to 100 lbs.
Trunk is Exterior dimensions: 37.187 inches x 18.00 inches x 14.375 inches
dlsmith
BX2230, LA211
Nov 15, 2018
1,237
794
Goshen, IN
Used the BX to lift the subframe onto my '70 Nova body. Have to get the subframe on so I can gett the fenders, hood, doors and radiator support fitted before it goes off to the paint shop. It hasn't been as long of a project as the genset I built, but I disassembled it in 2014 and has been setting in primer since 2017, so it's time to get it back on the road.
IMG_20210815_153528887 (Medium).jpg IMG_20210815_155330010 (Medium).jpg IMG_20210815_164352322 (Medium).jpg
RichardAaronlx2610
Aug 3, 2021
449
502
New Jersey
Very nice, that will do the job
4,347
So Japanese Stilt Grass causes problems for flail mowers?
I’m using a rotary cutter (aka bush hog) now that’s about the same age I am (not saying much for either of us). Had thought a flail might be a good option if/when it gives up, but not if flails can’t handle stilt grass. We have quite a bit of that.
bmblank
Mar 4, 2015
671
319
Cadillac, MI
Saturday morning I tried to use the fourwheeler to pull the lawn sweeper around. Couldn't get it started in the 10 pulls or whatever I was willing to give it so I decided to use the 7100. Well, the pine straw rake was already on it, so I decided to run that over the lawn a bit before sweeping. It did a number on it. Then while I was at it, I thought maybe I should go over the (mostly sand) driveway and see what happens. It surely didn't hurt it. Then decided to clean up the back yard (all sand) since I've been working back there and it needed a cleanup. Did great there, too. After all that I swapped to the sweeper and cleaned up the yard.
Then I put the brush hog on the 3901 and ran it for a while before breaking the tail wheel off.
Yesterday I gave the 3901 a bath and a grease job. Gotta do 50hr service to it, too, but I don't have the supplies yet.
3,809
I think if the flail had Y blade knives it'd work better for stilt grass. I have heavy hammers on mine and I think the slipping belts contributed.
ctfjr
L3800HST
Dec 7, 2009
1,947
2,446
central ct
As a part of my lawn redo I decided to level off the north side lawn. It's not very large about 50X50 then it goes into the woods. Before an ice storm took it down I had a productive grape arbor there.
In the past I had installed a pvc pipe for my woods cameras and I know it was only down a couple of inches.
So I brought over about 20 buckets of top soil and was starting to spread them with the back blade - being VERY careful near that pipe. Then I hit an inground bee's nest. Without thinking (never a good idea) I hit the reverse pedal and the corner of the back blade took out the pipe :(
The black line was where the pipe was. I spent Sunday digging a real trench, fixing the pipe (no real damage to the 2 cat 5 cables or 40v 14ga power wires) and then bringing more topsoil in to fill it in.
Although I crowned the filled in trench, it's pretty puffy topsoil and I know I'm going to have to bring more in.
