nbryan
Jan 3, 2019
1,251
785
Hadashville, Manitoba, Canada
Some real snow finally imminent, off with the loader and time to harness up the blower. Forecasting 10cm/4" tonight then Tuesday night maybe double that. Can only hope!
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,414
1,691
Kalamazoo, MI
I installed a couple of weld-on grab hooks, one on each side of my brush guard bracket for securement on the trailer. Got the damage all cleaned up and primed. Made a drawing for a couple of brackets to attach some clevis grab hooks onto the drawbar bracket using some existing bolts. Had to purchase some longer M16x1.5x50 bolts from McMaster Carr to replace the existing bolts.
Made a cool Reese hitch receiver for the lower tubes on my Farm Hand Quick Hitch...still need to prime and paint it, but it fits perfectly and will be very handy for moving the travel trailer in and out of the shop plus moving other trailers around the yard.
pokey1416
Jun 24, 2020
564
834
SW Michigan
Had chain so put together a length to hold stabilizers up. Chain came from Lowe's. It takes 35......not 34 links to work! Gonna wrap the station arm with something to prevent wearing the paint off it.
2,688
That looks vaguely familiar... ;)
Yours is prettier.
5,872
Ditch Witch has used a similar chain anchor for it's backhoes since the early '80's. Pretty simple, bring the outriggers up and hook the chain on each side.
Bmyers
May 27, 2019
3,329
3,932
Southern Illinois
We worked at the farm some more. Hauled a little over a ton of scrap this morning to the scrap yard. Since we had an empty trailer, we loaded it up with an old pull behind combine. It is one of those items we found buried long the fence line that Grandpa had parked there. Sadly, it had set so long it was beyond being salvaged. It came out in pieces.
We could only get about half of the old combine on the trailer, so the other half will probably head to the scrap yard tomorrow.
We also had lots of visitors in the field.
Magicman
Oct 8, 2019
5,579
7,812
Brookhaven, MS
knotholesawmill.com
We loaded and hauled logs today that had been salvaged from a power line tree trimming crew.
The first two of six trailer loads of logs.
The last trailer load of logs.
25 of the 32 logs that we salvaged, loaded, hauled, and stacked today.
Bmyers
May 27, 2019
3,329
3,932
Southern Illinois
We loaded up both trailers yesterday. Finished putting the pieces of the combine on one trailer and put the old corn picker on the other trailer. Continue to get things cleaned up.
Ended up having to work on dad's MF383, the alternator had come loose. A little bit of prying, got it moved back into place and bolted tight.
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Finally dragged the chains out and using LouNY's preferred method, got them mounted in just a few minutes with no lying on the ground or sweating and swearing.
It did take a lot longer to get all the side and cross chains properly adjusted including a trip or two to the shop for more connecting hardware.
But it is done and just in time for the predicted warming rain event that will likely turn everything into ice when the temps drop back down below freezing😲
Magicman
Oct 8, 2019
5,579
7,812
Brookhaven, MS
knotholesawmill.com
You are making good use of the Thumb.
Absolutely!! That Thumb is the difference between handling and not handling.
I failed to mention that all of those logs were bucked to length by the landowner with a 20volt DeWalt chainsaw.
The logs are mine just for hauling them off. He wanted them gone before Christmas so I got an early Christmas present. I will saw them into framing lumber for my Son's pole barn.
Bmyers
May 27, 2019
3,329
3,932
Southern Illinois
Took the grand-nieces out to the farm. The littlest one was to busy running around and exploring everything. The older one wanted to ride on the tractor and learn how it works. She was able to pick up some old power poles we had. If I'm not careful, I'm going to lose my nice comfortable job inside the climate controlled cab.
bird dogger
Vendor Member
Feb 24, 2019
1,635
1,524
North Dakota
That's a Proud Moment!! Sure doesn't take them long to catch on, does it?
bird dogger
Vendor Member
Feb 24, 2019
1,635
1,524
North Dakota
She figured things out quickly in the Kubota and was smiling from ear to ear.
Your picture reminded me of this:
At about age 30 when I bought my little JD750 TLB to use on some acreage I owned on a lake. I became good friends with a family that has an adopted son who is mentally challenged in some ways. He was around 12 yrs old at the time. His parents kept very close tabs on him but would let him be with me as we both greatly enjoyed each other’s company. He kept mentioning that he wasn’t allowed to do much at his place so he really enjoyed helping me. I told him as long as he was helping me, I would teach him whatever he wanted to try.
Of course, the first thing on his list was the tractor/backhoe. I found a spot in the woods to set it up and in no time at all he knew how to safely run the hoe at low speed. I’d move the tractor and set things up and he plucked small tree stumps (actually brush, but to him they were trees) and dug holes to bury them in. After a couple of hrs. I told his parents I had something to show them. Can’t remember who was smiling the most between us all. Their son and I have been best friends since. He’s now in his 40’s, has a driver’s license and works for a construction company. He has never forgotten the day he learned to operate heavy equipment! 😂
Reactions: 10 users
BigG
Sep 14, 2018
1,951
772
West Central,FL
The only reason you get to use that tractor is your dad doesn't know where you hide the key!
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
I pulled the lawnmower out and moved a light bale of hay, I'm guessing about 400 pounds, through the mud in the yard into the mud in the pasture and stuck it in the lean to for the horse to enjoy. I tried to post a video but my phone makes videos as MP4's, and the forum don't like those. Almost had to leave it out in the pasture, because I drove over a piece of wood that was left out there, and when I tried to back out, it was hitting the front axle. Had to wiggle wag it until it slid in the mud enough for the tire to hit it instead of the axle. I'm a city kid living rural, and I kinda like it.
old and tired
L2800 HST; 2005; R4
Took the grand-nieces out to the farm....
I think everyone remembers their first tractor!!!
In low gear, they can't get too far that I can not catch them. I've put 12 year olds behind the wheels for them to drive around.
For work, I usually let the better summer workers run 100+ hp; 6 to 8 wheel tractors. Snapping photos for their dads, with them sitting behind the wheel (making sure they have the correct model number of the tractor...)
Shoot some of our Grad students are happy to get to drive our smaller tractors... There's just something about driving a tractor!!!
Old_Paint
Dec 5, 2020
1,762
1,781
AL
My 12 yr old granddaughter is pressuring me about driving my new LX2610SU. I've let her drive the little orange one (Husqvarna) which also has hydrostatic drive, and she did OK, but I can walk as fast as it goes. Just not sure what I can do to suicide the big orange one if it's too much for her. It is cool to teach the young ones, though, and now I know how my step-father's dad felt the first time he let me drive the Cub Farmall, and then the 8N, and finally, the Jeep. My mother had no idea I was driving anything for nearly 2 years. Maybe I'm just not as ready for her to grow up as she is to do it anyway.
Bmyers
May 27, 2019
3,329
3,932
Southern Illinois
Keep them young as long as you can, the world tries to make kids grow up to quick.
Yet, when she is ready, be the guiding loving hand that so many kids now days lack. I was EXTERMELY lucky, I had two great-grandfathers and two grandpas when I was young. All the way into 30s, I still had a grandpa with me. My grandfathers shared so much with me and I have such wonderful memories from them. The older I have gotten the more I appreciate and miss each one of them. I'm blessed to still have my father and as you have seen from multiple post we get to spend just about every weekend together working on the farm. You may never know how much of an influence you have on that young girls life, but take it from me, grandpas are awesome and make a HUGE difference in each grandchild's life.
