Jim in La.
L3302,5105 JD, ‘49 8N,1951 8N
May 24, 2025
Louisiana
I removed the loader from my new L3302 for the first time then disked the garden spot for the fourth time hoping it will dry out( love that FWA ). Then I dropped the disk and put the quick hitch on (heavy sucker) and hooked up my 5 ft. light duty rotary cutter. It was 92 with 60% humidity this afternoon so I stayed in and then went out around 7 and cut grass for an hour or so. I now have 15 hours on the tractor and should be getting a regen soon. I've been running 2500(PTO) to 2700 RPM (disking). I replaced the plastic toolbox with a 16"x4"x4" steel one Last Friday. Mounted it right where the plastic one was. I've got to modify my tiller,hipper,box blade, and disk to work with my quick hitch. I have the forked top link adapter and was successful connecting the rotary mower. The rest of the stuff needs the A frame top link braces relocated to allow the hook to be used so I can just pick up and go. I love this tractor.
Old_Paint
Dec 5, 2020
1,805
1,856
AL
You got a link for the box, or did you build it? I have 4 payments left on my LX and want something a little larger and a lot tougher than the plastic box. I put an ammo can on each side of the ROPS bar using existing holes and could add two more if I make a couple more brackets, but having that box that close is the best storage for pins, clevises, bushings, etc. I keep a few basic tools in the ammo box on the left and a 20’ 5/16 chain on the right. Quite by accident I found that the inertia of the chain coming out of the ammo box keeps it from hitting the fender. It actually shoots out past the oversized R14T. Who knew?
Siesta Sundance
Oct 23, 2022
1,791
2,505
youtube.com
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
153
154
My 81 year old neighbor had some trees removed from his back yard. The tree service had to move his car hauler trailer so it wouldn't be in the way while dropping the trees. They didn't put the trailer back when they finished.
He asked me if I could use my tractor to put the trailer back where it was. It took me 5 minutes.
After thanking me he told me at 81 even 5 minute jobs are exhausting.
nerwin
Nov 13, 2024
474
1,021
Vermont
youtube.com
Have any of you made a cylinder safety stop for your loader? I'm looking for fabricate my own. I was just wondering because it will be a lot easier and a safer to service the tractor. 10 more hours until first oil change! Gonna replace the filters too, might as well change the fuel filter while I'm at it. It doesn't look bad at all but can't hurt. The air filter needs to be changed as well. Gonna be a pricey day at the dealership getting the stuff 😭
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
251
159
WNY
I have
I have just removed the loader when doing service, only takes a few minutes, and better access to everything.
nerwin
Nov 13, 2024
474
1,021
Vermont
youtube.com
I have
I haven't tried taking it off. A little scared to be honest because I'm worried I'll screw it up haha and never get it back on. I watched videos and people make it look easy but nothing ever goes easy for me 🤣
4,647
Only “trick” is take it off on a flat place big enough to be flat for both tractor and loader, and solid enough the loader stands won’t sink into the supporting surface. Flat concrete/pavement is ideal but not necessary.
First off/on took me 45 minutes. I knew I had to take it off for some of the routine mowing I bought it to do, so it wasn’t optional for me. Now it’s less than 5 minutes off, same putting back on.
If I didn’t have a flat spot, I’d get some angle iron and make some cylinder blocks or buy them.
nerwin
Nov 13, 2024
474
1,021
Vermont
youtube.com
I have a flat driveway with plenty of room. I feel confident I can get it off easy but aligning it back on to get the pins to slide into the frame will be tough I think.
jkavanagh58
L3302
Feb 17, 2025
11
32
Avon Ohio
I'm getting ready to order an L3302 or L3902 and am putting together my purchase list and "wish list". Not sure which list the quick hitch should go on. Sounds like a useful addition but not sure if it is justified at this point. I will mostly be switching between a rotary cutter and box blade on the rear PTO.
The Quick Hitch has been a nice add to my 3302. It works great with my Land Pride implements but I have had issues with another implement.
Orange man
Jul 23, 2014
251
159
WNY
The pins self align when you tilt the loader back onto the brackets.
8,494
Nice! Was it plug and play?
Basically yes. Just unplug and remove the factory cigarette lighter (unscrew the metal retaining sleeve), open up the hole a bit to 1-1/8", install the USB outlet, tighten the retaining nut and reconnect the spade lugs. Blue Sea Systems products are designed for boats so need to be rugged and weatherproof. There's no illumination to fail, just good quality plastics, a simple appearance and some clever internals. This USB outlet will work well on an open station or cabbed tractor.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,448
1,663
Near Lancaster, PA, USA
This is my third Kubota with a loader. I've had the loaders off and on hundreds of times because I don't have the loader on unless I'm using it. There were two times in 23 years that were a genuine struggle. Both were due to stupidity.
Once was when I wasn't paying attention and didn't put the right side pin in while re-mounting the loader. I hopped out while the tractor was raised on the bucket edge and rear tires. Sometimes that's when I put the support arms in the carry position. That's what I did and only realized my error when I tried to lift the bucket. The right side of the loader frame popped out of its receiver. The hydraulics were no help. Fortunately it was in the shed, so I used a small lever chain hoist to get it into position.
The other time was when I was in too much of a hurry to drive to a better (more level) spot to drop the loader. It came off without a hassle, but it was very difficult to reinstall. Fortunately #2 Son was visiting. Various pieces of wood, a digging iron for lifting, and a second pair of hands to place the cribbing and we managed to get it back on.
nerwin
Nov 13, 2024
474
1,021
Vermont
youtube.com
For some reason I thought the hydraulics on the loader would drift but the fluid has nowhere to go as it can't go back into the tank, so it should stay where you put it right?
chim
Jan 19, 2013
2,448
1,663
The pin I spoke of was part #100 below. The hydraulics of the lift cylinders are connected to each other. Unless both are physically connected to their "load" the connected cylinder won't move the load and the hydraulic flow diverts to the loose one and it will just go back and forth in the air.
When I reinstall the loader, I usually stop short, connect the hoses, then drive in closer. At that point I pull the stick as you would to raise the loader. The two frame sides rotate toward the tractor to meet the two main frame pieces on the tractor. Frequently the movements of the two cylinders are not exactly in sync. After the first one contacts the main frame, the other moves till it also touches its main frame.
Then dumping the bucket drops the frame sides into the main frame. A little more rotation or a little down pressure on the loader lifts the front wheels. At that point BOTH! #100 pins go in (not just ONE as I did) and the two stands can be raised and pinned. Next the loader is lifted and off you go.
in my case with the right #100 pin not installed, the right side of the frame jumped out. With the stands already in their stored position, the hydraulics couldn't help me. The loader was sitting too low to allow the stands to be rotated into their lowered position.
nerwin
Nov 13, 2024
474
1,021
Vermont
youtube.com
So with the loader sitting in the frame cradle but yet pinned in is strong enough to lift the tractor? It wouldn't bend the support arms?
