Weight of filled tires?
OntheRidge
Nov 1, 2020
286
333
I ordered some Bora wheel spacers for my L2501 with R4 tires, which I will need to remove to install spacers. Does anyone have an accurate weight for a filled 15-19.5 tire? Filled with WW fluid. I tried searching here and elsewhere without a definitive answer. Thanks, all!!
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
328
89
Ottawa, ontario
I filled the back tires on my B2601 and reguardless of the tire weight I jacked one side at a time so the tire just left the ground. Very easy to handle a heavy tire if you don't lay it down.
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
575
413
central ny
Are you concerned about handling them? I just installed a set of those on my L2501 with the R14 so they should be about the same weight. I asked here and was able to do it by myself. They were not bad at all to keep upright and roll forward. I am 68 and not as strong as I used to be so I asked here too. Was only hampered by not being able to rotate hub when out of gear as I have a DT not the HST. After words I described it and someone suggested maybe it was in 4wd and it was! I will see if I can find the thread I wrote. It was only about a month ago.
Bill
Chanceywd
Mar 26, 2021
575
413
central ny
I think I copied this right!
OntheRidge
Nov 1, 2020
286
333
That is my concern, thanks for the reply and the link. You give me more confidence that I can handle them!
ayak
L3301 HST
Feb 16, 2018
576
748
WV
201# for an unfilled tire, it looks like. I took mine off and used my BH77 along with some supporting jack stands to lift the rear just enough to slide the rears off when I did my rear Bro-tek spacers. And be sure to take it out of 4WD so you can rotate them as needed to get everything lined up good for getting them back on.
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
102
55
Traverse City, Michigan
Maybe this will help
enter you tire size in the interactive tire fill tool and it will give you the gallons
For your tire its either 24 or 29 gallons in them multiply that by the 7.6 lbs for winshield washer fluid or 8.6 for water and you will have the approximate weight for the fluid.
i will just use 29 gallons as worst case scenario that makes 220 lbs just for liquid plus the 201 for tire thats 421lbs is minimum weight. i couldnt find a rim weight so total weight is probally more than 500lbs.
Tx Jim
M7040 HDC-1,JD 4255,Ford 6700
Apr 30, 2013
1,187
118
Coyote Flats,Texas
Ontheridge
Easy peasy to R&R your tractors rear wheels/tires. Just keep them balanced close to straight UP. Just take your rime & be very careful.
Back when I was employed at JD dealership in the early 70's JD had a warranty program to change rear axle/final drive housings on several JD 4430 tractors(125 hp) from one side to the other. We had to R&R by hand liquid filled 18.4X38 rear tires.
4,376
8.33 lbs. per gallon is the correct weight for water!
7.6 lbs. per gallon is correct for WW fluid.
4,249
rule #1 ALWAYS have a CLEAR path to run AWAY from a falling tire !
Loaded tires are HEAVY and AWKWARD
rule #2 ALWAYS have a short 2by4 handy, to toss under the falling tire !
you toss it under the falling tire, makes it easier for 2-3 guys to get it upright again.
