Using the W.R. Long 3rd function valve to run rear remotes
Dae06
170
11
Minnesota
I think I'm ready to try to set up a rear remote on my Kubota B2650. Has anyone used the 3rd function valve and run hoses to the back of the tractor for rear remotes. I am a novice with hydraulics and just trying to figure out the correct coupler sizes, hose sizes, etc. are going to be tricky for me. This will primarily be for a hydraulic top link, but will want it so it can be used for anything in the rear of the tractor. To top it all off, I have a cab which may make running the hoses a bit tougher.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,385
1,658
Kalamazoo, MI
Haven't done it personally but don't see any compelling reason why you couldn't or shouldn't.
old and tired
L2800 HST; 2005; R4
I don't know anything about the 3rd function valve - I installed a 3 spool valve for grapple, top and tilt. Can you feather a 3rd function valve? I thought it was an all or nothing type flow valve - great for a grapple but for a hydraulic top link, I need to very slowly get it where I want it to be. Just something to find out from others that have this setup....
