Using the drawbar to pull a trailer
DawgHouse
Kubota L3302
May 2, 2025
Good Hope , GA
I am a new Kubota owner. For clarity, when I say drawbar, I mean the bar coming straight out under the PTO with holes for adjustment. Here's my question...I am trying to pull a trailer (not fast or long distances). It is a 7000 lb 20' car hauler. Not sure of weight but I'm guessing 1,000 - 1,500 lbs. I've heard a lot of warning about pulling with the 3PH so I'm ruling that out. If I attach a ball directly to the drawbar, will that work safely? And, will I be able to raise the quick hitch high enough to keep it out of the way of the trailer when turning? Thanks for the help.
bird dogger
Vendor Member
Feb 24, 2019
1,677
1,582
North Dakota
I do the same with my B2650 and my car hauler trailer. I'm assuming moving an empty trailer? If so, you should be just fine.
I don't have/use a quick hitch so I can't comment on that. Other than raise your quick hitch up and check for clearance against your trailer tongue. I'd also guess you'd be fine. If the clearance is close, you could move your top link attachment to the other hole on the tractor mount to raise the hitch up even higher?
Ping
BX2370-1
Dec 25, 2018
331
286
Troy, Ohio
Not sure what speed, terrain & how loaded the trailer you plan to pull is but, yes, absolutely you will be able to pull from the drawbar. If traveling at high speed, stopping will be your issue. I have occasionally dragged my 18' trailer behind my BX when cleaning up trees in the yard without issue. As you noted, don't use a 'drawbar' across the 3pt arms.
I would think your 3pt raised up will clear the trailer tongue but, you'd have to be turning pretty sharp for that to be an issue. Though, I could be wrong. Hope this helps.
ayak
L3301 HST
Feb 16, 2018
675
925
WV
I’ve done it both ways ok with my dump and equipment trailers (each about 2500lbs empty), to move them around on level ground for maintenance and such. Being able to stop is as much a consideration as anything, especially heading downhill.
DawgHouse
Kubota L3302
May 2, 2025
Good Hope , GA
Ping and Ayak, thanks. Since this is new equipment for me, I'm just looking for some reassurance that I'm doing this the best way. Property is relatively flat so I don't have an issue there. Thanks again.
1,709
But you will (probably) need to watch how sharp you turn and the trailer tongue might be able to hit the tracto’s rear tires. It depends on the tongue length and how much angle it flairs out.
Old Machinist
May 27, 2024
266
274
NE FL
I've never heard any concerns about pulling anything with the 3pt. What do you suppose it's doing when you pull a plow, box blade with rippers, tiller, etc?
I don't use my drawbar and leave it off the tractor. It limits my turning ability because the attachment point is inside the tires. I use a 3pt 2" receiver on a 3pt quick hitch. This keeps the attachment point out past the tires so I can make 90 degree turns if I need to. I have various ball mounts and even use one without a ball for pin attached implements. I even use it with one mount I made with a ripper for pulling roots and digging trenches.
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
59
Bayview Township
Might not be relevant. Different tractor but of similar size. The NH I traded in for the Kubota had a drawbar with a 1 3/4" ball mount hole. Used it for years pulling a trailer with a one ton max up and down some moderately steeper pitches (>6%) loaded with firewood.
No plans to haul full loads using the BX. Going to give a receiver mount that attaches to the BX trailer mounting plate a go. The BXpanded quick on/off unit. Hopefully the 6"of rise and extension of the ball mount will give me adequate clearance without needing to remove the QH05. If not to liking. Was thinking about one of those 3 pt triangular shaped receiver units. So why is it some feel it might be a bad idea? Considering the wide choices. Must be relatively popular. Load limits? Stability issues? Or just someones internet opinion? Thinking more like Old Machinist.
Heehaw
MX5400hst Kubota Z726X
Oct 4, 2022
105
98
I think the main concern with pulling a trailer with the 3pt is the possibility of the trailer tongue lifting the 3pt if there isn’t enough weight on the front of the trailer.
With that said I have used my 3pt to pull my trailer full of firewood many times without issues.
8,212
You can get a three point hitch to move stuff around, that's all I use.
I have a B7100 and can move my trailers around empty.
The only thing to do with a three point hitch is to put a check chain on the hitch to the drawbar to keep it from going to high.
Warlordchet
SV97
May 2, 2025
Jefferson Georgia
drill a hole through the bucket and set a ball in the bucket. Pull trailer in reverse. Problem solved.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,078
3,297
@DawgHouse I move trailers a lot with the tractor. Only using the 3 point with a Heavy Hitch receiver. So much easier since I don't have to wind the tongue jack. Just raise the 3 point and go! Drop it where I want it and the tongue jack is still the right height for when I hook the truck up. My two largest trailers (other than the toy hauler are just shy of 6k. Dump trailer may be around 7 if it's got junk in the trunk.
