joekimtkd
B7510DT, 4' Snow blower, 4' Loader, 6' Blade, 6' 3PH Finish mower, 6' box blade,
I have a 6' snow blade that attached on the bucket of FEL.
and I use that snow blade to cleaning snow in my store parking lot.
When I pushing snow, it always leaves windrow on both end. so I wanted to add wing on each side. I'm thinking about a foot long and a foot high on each side and try to use 12 volt Motor driven hydraulic cylinder to adjust angle for both wings. I'm trying to make linkage and connectors for this but I'm not the welder. so I have to take it to welding guy in town but I have to show him how to make and so on...
Do you have any better idea on this matter~???
I mean, How to make linkage and connector and so on.
I have only one cylinder. and I wanted to make it to flat or 45, 90 degree angle to pushing snow. Just like the snow pusher but it will have the adjustable wing on both side.
and this 12 volt motor driven hydraulic cylinder came with snow blade.
It's been used to lifting and lowering the snow blade.
It is 14" long when it is retracted (hole to hole) and 21 3/4" long when it is fully extended. So about 7 3/4" travel distance. and I have to buy the wire and switch too. Where can I buy this switch?
When I use it in angle, it works good too but it pushes the snow to the side and keep on adding more and more. and eventually my tractor can't push it no more~
That is why I wanted to make this 6' snow blade as snow pusher now~!
If anyone could give me an advice on this, I'll be greatly appreciated~!!!
Joe.
Joe.
