Trash in the fuel tank? (L3560 HST)
9,061
Where is that hose? Really hoping to not have to take a ton of things apart since the tank is under the cab
It's the same if you have a cab or not.
It's under the tractor under the bellhousing between the 2 tanks, under the shield 2 bolts and one nut, can't get much simpler than that.
Russell L3560
Kubota L3560 HST
Jul 20, 2024
9
MS
I still have the same problem, even worse.
I called the dealer and they said it’s a super common problem but the tank has to be dropped and flushed. That hose is def easy to remove but I believe there’s more work once you remove the hose. That would allow the tank to drain but I’m going to need to break up whatever is clogging the inlet. I’m amazed that there are no videos of tank removal for an l3560 hst. If anyone has a link or other tips I’d be glad to hear them. Thanks!
