Transmission cooler
lmichael
Kubota G2160
Apr 23, 2021
692
318
Rockford IL area
So while rummaging around my garage I came across an old auto trans cooler I had replaced in one of my cars with a larger one. I am wondering if A, it might have some benefit to my G2160 HST and B, if so where would it be plumbed?
lynnmor
B2601-1
May 3, 2021
1,497
1,241
Red Lion
Can't give a real answer to your question. but you might be dealing with pressures much higher than the cooler is designed to handle.
lmichael
Kubota G2160
Apr 23, 2021
692
318
Rockford IL area
Perhaps. I also have a mechanical oil pressure gauge I would like to install. I know I would need to keep the switch in place as it is what turns on the electronic power steering. So I would have to do a T fitting of some sort. Not sure of thread size on the engine block though
BruceP
G5200H
Aug 7, 2016
852
369
Richmond, Vermont, USA
In hot ambient temperatures, it would not hurt. I suspect it is a LOW PRESSURE unit so must be installed in a return-line to the reservoir. (DO NOT REDUCE LINE DIAMETER...lest you may create a high-pressure zone)
You might consider plumbing in a 'bypass' for cold-weather use. Overcooling HST fluid is NOT GOOD for your tractor.
lmichael
Kubota G2160
Apr 23, 2021
692
318
Rockford IL area
Yep, not a bad idea though I only use the machine in warm weather. Although this past year I was using it until 2 weeks in front of Christmas. Mostly mulching leaves and such. I don't think there is a return line as small as the lines in and out of the cooler I have. So might be a pipe dream.
