I mentioned in another post that the tractor speeds were different at a given RPM and gear range depending on whether the Auto Throttle Advance (ATA) is ON or OFF. So today I took some time and made several trips back and forth on the driveway to see for myself what the differences were. All these numbers are the best I could get, although not truly exact.
The engine speed today was 2100 RPM for everything below. This is what I normally run at to get 430 RPM's at the PTO for the rear finish mower. Trans is in MED Rabbit with the ATA off. This works for most of the mowing season. Sometimes there are adjustments for tall juicy grass, etc.
