Tractor PTO Shaft - Hard to turn - is that normal?
eljuncal
B2601HSD-1, LP Tiller, Maschio mower Titan Forks, Woods Box Blade, Herd Spreader
Oct 23, 2022
44
41
Colorado
Hi, When hooking up my tiller to the tractor PTO shaft ... I needed to give the tractor PTO shaft a bit of a turn to get it to line up better ... and ... wow, that thing is very difficult to turn (by hand) ... I had my PTO, disengaged, PTO selector set to 'mid mount' and the tractor HST was in neutral ... is this normal?
3,685
Normal enough for Sloan to sell a wrench to turn it.
SDT
multiple and various
Apr 15, 2018
3,089
932
SE, IN
Most modern tractors have a PTO brake that stops the shaft from rotating when the PTO is not engaged.
Allows one to hook up by rotating implement shaft. If you cannot rotate the tiller shaft, you will need to use a suitable tool to rotate the tractor shaft.
Some (not all) will rotate more easily when the engine is not running.
RBsingl
Jul 1, 2022
408
425
Central IL
It sounds like Kubota applies a brake to all PTO shafts when not in use. When I set my Deere 955 to rear or mid, the PTO shaft not selected will freewheel and only in the both position are both braked.
You may find it easier for implements like tillers to hook up the three point and lift it slightly to facilitate turning the implement shaft for engagement but with the Deere I select the other PTO for hookup and then switch to rear PTO to lock the shaft allowing me to move the tractor slightly to rotate the PTO frame into proper position for the top link of the three point to attach.
Rodger
B737
LX3310
Jun 9, 2019
2,024
2,197
New Jersey
its new, it will get easier with time and spin easily. went through this twice with B2601 and LX, both became easier with use
B737
LX3310
Jun 9, 2019
2,024
2,197
New Jersey
i could not turn either by hand when new, after each had over 100 hours on rear PTO roughly, i can turn by hand, still tight, but not impossible. YMMV.
eljuncal
Oct 23, 2022
44
41
Colorado
Thanks to all who posted! Bought the wrench ... :)
bird dogger
Vendor Member
Feb 24, 2019
1,578
1,427
North Dakota
On my B2650 I need to have the PTO selector in "MID PTO" ONLY. Then the rear PTO stub began to rotate easier and is now easily rotated by hand. But....only for 15° to 30° either clockwise or counterclockwise. But that's more than needed to align the splines of whatever your hooking up.
Elliott in GA
Mar 10, 2021
636
619
North Georgia
FWIW, I rotate the PTO shaft to connect to the tractor PTO stub for my LP rotary cutter, LP spreader and WoodMaxx chipper.
However, I connect the PTO shaft to the tractor, and then I use the Sloan PTO wrench to rotate the PTO stub on my LP Finish mower to connect the PTO shaft to it.
You may find the easy way depends on the implement.
kubotafreak
Sep 20, 2018
1,022
375
Arkansas, US
FYI, Easy way to burn out that pto brake is to shut down your implements at operating speed. Ideally you bring the rpm down before disengaging the pto.
jyoutz
Jan 14, 2019
2,566
1,663
Edgewood, New Mexico
I have always attached the implement to the 3ph, then lift the implement to clear the ground. Shut down tractor, then rotate the pto shaft to turn the implement blade or tines to align with the tractor pto.
aaluck
Oct 9, 2019
932
746
Snowdoun, AL
Interesting topic. I was thinking about this the other day while I struggled. My new tiller is a PITA because you cannot rotate the implement side.
My PTO will turn in one direction, a short distance and then go back once you let go. Seems everyone's is a bit different.
derekuk101
M4900, M8540, M5-111 RTV 1140
Mar 25, 2023
Kentucky
On our M series tractors, we turn off the tractor, turn the pto leaver on, and then the shaft will spin freely (at least one full turn) to hook up implements.
Tornado
793
252
usa
I used my rototiller the other day and as I was hooking it up I remembered this thread and so I reached up to see just how easy my pto turns by hand on my L2501. Mine is SUPER easy to turn. I can turn it with just 2 fingers easily. Reading here some folks say it is pretty hard to turn. I wonder what the difference is. Mine is HST transmission rather than gear driven.
SDT
Apr 15, 2018
3,089
932
SE, IN
Bingo.
Always reduce engine speed to idle before disengaging the PTO.
I always do so and also lower mower into uncut grass or heavy debris as I disengage.
Lots of horror stories about the weak PTO brake in M9540/9960 and similar models requiring many thousands to repair after catastrophic failures.
