Throttle control lever
Alb$$
Bx2370
Aug 11, 2023
Middleburgh NY
My BX2370 throttle control lever(increases/decreases engine RPM snapped off after about 100 hrs. Dealer said the part is discontinued and is looking around if another parts place has one. So far no luck…. Has anyone had a similar problem and have found a fix? Appreciate anyone’s advice
JasonW
238
101
Al
Kubota #K2581-45126 LEVER, ACCELERAT
I found this for $18 on Messicks(kubota dealer). If that’s the actual part you need.
lynnmor
B2601-1
May 3, 2021
1,333
1,045
Red Lion
Is this what you want?
5,277
3,081
I think you should NAME the incompetent and unhelpful Dealer.
Alb$$
Bx2370
Aug 11, 2023
Middleburgh NY
Thanks to everyone for replying. Messicks has it in stock and it’s been ordered. PS the parts guy never called back Sharon Springs NY Kubota. The lever was getting very stiff to operate, but never expected it to break off especially since only has 100 hrs of use.
whitetiger
Nov 20, 2011
2,614
1,132
Kansas City, KS
When the throttle lever gets hard to move or too loose to stay where you set it, there is a friction adjustment on the bottom that needs to be adjusted.
Steve67
B2601-fel, 60"mmm, 5' rear blade, balast box
Jan 20, 2017
324
102
St. Louis, mo.
When it comes to parts and diagrams, you can always count on Wolfman. 😎
