gpreuss
I finally got really fed up with my R4s, so I got some R1s to replace them. The actual on-the-ground tread actually went from about 13" to about 11.5", but the diameter went from about 40" to 45+", and the traction is way up!
Then, rather than try to fit my chains on the AGs, I bought 4 boxes of #14x5/8 hex-slotted sheet metal screws (#14 is 1/4" in diameter, with a 3/8 hex shoulder head). So far, traction in serious snow and ice is fantastic with no pulled screws - I'll keep you posted.
To keep the same general stability with the AGs, since the tractor became about 2-1/2" taller, I needed to space out the rears 2-1/2" wider on each side. So I wanted to space out the fenders to keep them over at least part of the tires. I bought about 6 feet of 1-1/2X2-1/2x3/16 rectangular tubing, cut and drilled them, and spaced out the fenders.
The 4th and 5th pictures should be swapped...
More to come.
More to come.
