Strange request: Pine Needle removal
W7AX
L4310 HST, Bush hog mower, two different buckets for front end loader, Land box
Mar 23, 2018
58
Polson, Montana
This might be the weirdest question yet. I have a lot of very large pine trees, over 150 of them on my property here. They range from 2 feet to 3 feet in diameter and most are 150 feet high or more. Needless to say, they lose a lot of needles each year and it takes a very long time to manually rake them up and get them to a burn pile. I'm trying to imagine a machine that could at least get them in windrows so they are easier to pick up. I've even thought of designing and building a special machine that could do this. A side delivery rake comes to mind but it would have to be smaller that the ones I've seen for farm use. Even thought of a huge vacuum cleaner type rig. Has anyone ever had this same problem or even know of a machine that could at least help with the chore?
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
Re: Strange request
Here you go, pine needle rake from EA Attachments.
https://www.everythingattachments.com/Tractor-Pine-Straw-Rakes-Pine-Needle-Rakes-s/3425.htm
W7AX
Mar 23, 2018
58
Polson, Montana
4,686
Re: Strange request
How bout one of these :rolleyes::p:p
Sent from my SM-G920V using Tapatalk
W7AX
Mar 23, 2018
58
Polson, Montana
Re: Strange request
I do use one of those...right after I get the needles all in a big pile :)
Grouse09
B2650 Cab, snowblower, FEL, brush hog
Aug 24, 2016
139
Traverse City, MI
Re: Strange request
I use a needle rake from Tractor Supply for pine needles, branches and de-thatching the lawn. I tow it behind a 4-wheeler because I don’t want the tractor on the sprinklers or septic tank. It does a great job as I am sure the ETA rake does a well.
vic gerbasi
M110 L3300
Feb 19, 2016
232
dugald mb canada
Re: Strange request
Really !!!! all he had to do is adjust the top hook on upper link and then weld an adjustable brace to hold the height leg up when not in usre
