So, here's the deal-
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
So, here's the deal- PTO drive gear-7001- 7100
I need this gear. Older 7001
Anyone got a part number? There is a serial number break..early and late....I have an older machine.
17T
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
I've done business with the same dealer parts guy for some time now, bought quite a bit of stuff from them over the last year and we know each other by name.
The one consideration was the serial number, I had to explain this time that it was actually a grey 7001 and believe it or not they were cool about it.
Here's the part numbers for the 7100-
early s# part# 66711-14530
and the late s# part# 66706-14530
Have any of you guys replaced these parts yet?
There is a discussion about the grey numbers not matching up to the NA numbers....I wonder if this is more about s# breaks than anything?
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Thanks Vic.
A couple of local dealers here say the part 66711- is still available and one dealer has ordered it for me.......coming on Tues........we'll see.
In the meantime.........anyone got a parts tractor?
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
You my find another option would be to pick-up a used complete B7100 rear end and just swap over the complete assembly.
I had a good used b7001 rear end here until recently sitting in the garage, sold it for silly money just to get it out of the way, you may find a used item for a lot less mone than you think, and save a lot of work too.
good luck anyaway.
rob
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
good luck anyaway.
rob
I have spent the entire day looking through every craigslisting within 1000 miles and at least called 20 dealers......nothing.
76_Bronco
B7200 4WD w/FEL, 4' disc, 4' Brush Hog, 14" Plow, 4' Blade, JD 246 2 row Planter
Mar 28, 2012
182
Rainsville, Al
kubotasam
Apr 26, 2010
1,202
125
Alfred Maine
Have you talked to a "really good" welder/machinest about rebuilding the tooth? I once had an old Terratrack bulldozer with a chipped tooth on the final drives. I took it to the best welder I knew at the time. He built it up with TIG and ground the tooth back into shape. It workrd fine.
