Snowblower chute rotation
GaryInMontana
Kubota LX3310
Dec 17, 2024
Gallatin Gateway, MT
The plug from toggle that goes into diverter was the issue. Plug has insert that pops out with 3 wires. Ground wire had detached. Reattached and works like new. Also fuse for this oper. Is under dash on this model. Newer models have fuse under boot on hydraulic lever.
My local Kubota mechanic walked me through troubleshooting with a multimeter and the problem ended up being a blown 5-amp fuse. If the fuse is blown, the diverter will default to the up/down mode only - you won't be able to rotate the chute. The wiring on my LX3310 went from the toggle switch (which selects up/down or right/left rotation), under the floor mat and up to the fuse box. Along that wire somewhere there is supposed to be an inline 5-amp fuse. Mine was hidden under the fuse box which required me to remove the 2 bolts on either side, and I found it zip tied to the wiring harness underneath. I replaced the fuse, fired her up and good as new.
Since then, I have blown 2 more of the 5-amp fuses. So it may something that's causing it, or I just bought a bunch of crappy fuses (the most likely scenario). Or maybe it needs a 10-amp fuse?
1,741
Don’t just increase the fuse size or something else will melt (wire or components).
I would inspect the wire under the floor mat for chafed insulation or bare wire.
WAS BANNED FOR NSFW PICS
5,143
Buy a name-brand fuse, not the no-name Chinese fuse. I purchase "Buss" branded fuses and they last a long time. When I bought an assortment of Made in China fuses, they gave me nothing but grief just like Chinese food does.
Dustball
2016 B2650HSDC
Sep 15, 2023
389
246
Hudson, WI
#1- don't upsize the fuse without checking the wire gauge for the entire circuit.
#2- measure the actual current draw of the solenoid to determine if the 5 amp fuse is adequate or undersized. See #1 before changing fuse sizes.
#3- most likely it's a short somewhere, not the fuse itself.
#4- the default is left/right chute rotation, not up/down. I think your hoses for the chute rotation and up/down are reversed with each other/installed on the wrong ports.
