single action cylinder question(s)
7,598
So looking at the schematic below, I'm confused by the suggestion "You can connect the unused port to a tank return (recommended)." For example, if I'm using ports 2a and 3a to control a pair of single acting cylinders, are you suggesting connecting 2b and 3b to a tank return?
Dustball
2016 B2650HSDC
Sep 15, 2023
362
239
Hudson, WI
This is an easy way to visualize the hydraulic circuit.
-When the spool is moved to the A side, the cylinder extends and the air inside the cylinder is vented through the breather.
-When the spool is moved to the B side, the cylinder retracts and the fluid is returned to the tank for both the fluid coming back from the cylinder and the fluid coming from the pump. Air is drawn back into the cylinder through the breather to prevent a vacuum.
-When the spool is in the center position, the fluid coming from the pump is circulated back to the tank.
For the single acting cylinder, you'll need a breather on the open port and a directional flow control on the connected port so the load doesn't drop like a rock.
4,734
I tried to clean up the schematic in the WSM for clarity, but this is the stack of three open center auxiliary hydraulic valves or rear remotes when the levers (valves) are in the center (neutral) position. There are check valves to prevent flow back towards the pump.
Here's the flow when a valve is activated, let's call it position 1.
Here's the flow when the valve is activated in the opposite direction.
There is no questuon the main PRV will unload at max system pressure. If it did not normal operstions woild fry the pump in short order. The PRV in the loader valve will do the same.
My point was and is you can prevent the system from unloading through the PRV with a simple tank return.
4,734
-When the spool is moved to the B side, the cylinder retracts and the fluid is returned to the tank for both the fluid coming back from the cylinder and the fluid coming from the pump. Air is drawn back into the cylinder through the rklfts breather to prevent a vacuum.
Depends on the cylinder design. A true displacement type SA cylinder has no internal seal,only one port, and dies not have a brearher. Different animal than a DA cylinder being used in a SA application.
They are inexpensive, trouble free, and have been used on agricultural equipment for better part of a century Common examples are snow plow angling and forklift mast cylinders.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,214
139
Coyote Flats,Texas
I operated one way cylinders on my H&S hi-cap rake on a Ford 6700 for over 15 yrs with no hyd tank return that gave no hyd problems. That set-up raked several 1000's of acres. I also operated one way cylinder on disc cutter on a Kubota M7040 with hyd hyd oil tank return with no known hyd problems. YMMV
4,734
I would have expected a SA/DA switchable valve like this on a Ford 6700.
7,598
I don't understand where the tank return would be installed referring to the schematic that I created and posted above (#21) and again below. The oil is returning from where? As the pump starts to dead head when the piston reaches the end of its travel, the only way to relieve that pressure is to allow the valve to return to neutral or for the PRV to open.
4,734
I don't understand where the tank return would be installed referring to the schematic that I created and posted above (#21). The oil is returning from where?
Pressurized oil is returning from the unused remote coupler so it is not dead headed during retract.
Connect a small (1/4") hose to any sump return point on the transmission and use a male quick connect to plug it into the remote when operating a SA implement. When not on use simply tie it up out of the way. Just like Kubota does on some of the backhoes.
7,598
So like this? When the valve is out of the neutral position 3b (in this example) is directed to the tank so why would there be pressure in the line to 3b?
4,734
You have diagrammed extend which works fine.
When you move spool to retract 3A is connected to tank and 3B is connected to pump. If 3B is not connected to anything the pump and valve hit max pressure and the pump unloads across the PRV until the spool is returned to neutral.
Dab
7,598
Dab
Wouldn't pressure be required from 3a as I've shown in order to retract the piston and raise the wings? See the cylinder in the photo below. I'm assuming that pressure is acting on the backside of the piston thereby driving the piston to the retracted position. I would also assume that this cylinder doesn't need a spring since the weight of the wings will extend the cylinder if there's no pressure at the inlet port of the cylinder.
4,734
No. Thats fundamentally wrong.
On a SA cylinder pressure is only used to extend the cylinder
To retract it the cylinder is connected to tank and the force of gravity/load pushes the rod in.
7,598
This is really confusing. 😂 Look at the wing cylinder when the wing is down. The piston is fully extended. To raise the wing, the piston has to be retracted. Based on the location of the inlet port to the cylinder, I'm not following your logic.
4,734
Those cylinders are an odd construction. Ordinarily the hose would go to the base end which is plugged. My guess is if you look at a component breakdown you will find there is no internal piston and seal. Oil entering the top travels down to the base end around the rod and the resulting pressure against the base of the rod forces the rod out. Its a displacement cylinder like I pictured above and can be fed from either port. Kind of clever.
7,598
Here are the cylinders on the folding cutter. There are two 810-150C cylinders, one for each wing, and one 850-217C for the center deck. I've added the schematics from the part manual for the RC3712.
4,734
OK -looks like it is pressure retract and gravity extend. Basically a DA cylinder being used for SA operation. You still have max pressure on the unused work port during gravity extend.
7,598
Funnily enough, last summer after I had finished cutting around my place, I raised the wings but the tractor and cutter were on a slight incline (left to right). I had to push one of the wings over the vertical position in order to get that one wing back on the ground. 😂
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,214
139
Coyote Flats,Texas
Ford 6700 tractor that I owned could have had that type valve but I never looked for it due to my 6700 have a cab obscuring sight of the valve body & the fact the single acting cylinders lowered rake wheels with no problems.
5,476
It looks like a DA cylinder to me. Maybe they plumbed to the 'rod side' for less speed (area is reduced by rod area) ? Not much, but normally you plumb the other way. Bet LP uses that cylinder in a lot of applications and this 'configuration' works well for the wings ?
4,734
Its a stock Red Lion DA cylinder plumbed for a SA application. They used the rod rather than base end to make it pull rather than push..
