I purchased a Kubota L3830 with glide shift transmission about five years ago. It is used very little ( 400 hours ). I don't have a shelter for the tractor and it is unfortunately stored outside. I am having problems with the shifting.
When I move the level to shift gears, the lever moves but it doesn't shift to the correct gear. For example, I can put it in forward and move the shift lever to 10th gear, but the tractor will only go to 4th gear. The highest gear that the tractor will go in is 4th or 5th, depending on the day.
I am wondering if the problem is the switch where the shift lever attaches.
Any ideas ? Thank you !
Vincent
Vincent
