Shifting issues with M6800
matt86
M6800
Feb 17, 2025
Missouri
I bought a used/single owner 01 M6800 last fall. All around it's in good condition. Has about 4600 hours. Besides some wear and tear items I'm replacing, I'm trying to get the gear shifter straightened out.
Those that don't know, it's a 8 speed, 4 high 4 low. Doesn't matter if it's in high or low range. Shifting between the left or high side of the H pattern (1/2 to 3/4 or vice-versa) is very difficult. Like it doesn't feel like it doesn't go between. I've only pulled the access cover off just below the lever. Linkage seems tight/no slop.
Has anybody else had this issue with a 6800,8200, or 9000?
7,471
Need to known exactly which model you have, there are several variants.
Do you have the WSM?
