Screwed the pooch....
Atlanta Panther
Kubota L3200HST with Loaded R4 Tires, LA524 Loader and Quick Connect 66" bucket
Jun 15, 2013
71
Madison, Ga
So I normally attach a drag harrow to my RCR1860 rotary cutter when cutting the pasture to help break up the horse manure piles. Anyway, yesterday without thinking I backed up over the drag harrow with the cutter turning. Of course, the harrow was broken into about 10 pieces but my bigger concern is the cutter. When I looked at it the two cutting blades were right behind each other. I am not sure but I suspect that the bolts holding the blades were just loosened and if tightened up again they would be fine because it doesn't look like there is any real damage to the cutter or blades. In fact, the harrow getting torn up knocked off some of the built-up grass clippings stuck underneath the cutter housing. I also did turn on the rotary cutter at an idle and it seemed to turn fine.
Is there anything else I should be looking at or should I just tighten up the bolts? Just want to make sure safety precautions are taken before I put this back into full service.
Thanks!
SidecarFlip
Banned
551
On both my choppers (bat wing and flat) Land Prides, the blades are free swinging. In fact, on the bat wing in the raised position, both blades hang straight down.
BigG
Sep 14, 2018
1,951
767
West Central,FL
It sounds to me that the cutter's stump jumper and blades did their job. The blades should be swinging free.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
The blades are fine unless they're bound and can't swing out. In that case you may need to "encourage" them to swing out. There is a reason the bolts aren't tight. Centripetal force keeps the blades out unless they hit something.
3,198
I believe you are describing Centrifugal force, that force which slings the blades out in an arc.
Centripital force is the force felt by the spindle/stump-jumper near the bolts...or the force which tries to stretch the blades toward their inner end. ;)
kkk
Banned
rtv900 /u15 ex/WP 955/woodmizer LT15
Apr 10, 2020
47
OreGun, BLM
Bolts should BE tight.
Mine have a shouldered area where the blade is to allow blades to swing.
Bolt threads into plate above stump jumper then a lock washer and nut lock it in place from top side.
I'm sure other Brands may differ slightly.......
