RTV900 Pump shaft
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,130
127
Hardisty, Alberta
Hi
Have any of you ever removed the pump shaft on an rtv900 hydrostat WITHOUT completely disassembling the transmission?
I need to replace the pump swash plate and to do so the pump shaft needs to be removed . the WSM says to tap it out towards the rear but they are assuming I have the transmission all apart. If it can be removed from the rear it will cut off about 8 hr's labor to completely remove the engine and trany and disassemble! There appears to be nothing stopping it except the press fit on the bearing behind the charge pump. even if I have to damage the shaft to get it out it would be worth it as the shaft is only $80.00.
ED
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
I know you can get all of the rotating groups out when removing the valve block, but not 100% sure about the shaft.
eserv
May 27, 2009
2,130
127
Hardisty, Alberta
Yes, I have the rotating groups all out. The swash plate is broken on the pump and it won't come out with the pump shaft in place!
Ed
eserv
May 27, 2009
2,130
127
Hardisty, Alberta
Well I put a puller on that pump shaft and it comes out alright. problem is the coupler inside the transmission came off and fell inside:( I removed the rear axle and the right side brake assembly and have good access to reinstall the shaft and coupler. will save at least 6 hr's doing it this way so I think it's a good procedure.
Ed
KubotaTech
Apr 1, 2010
185
PA
That is pretty slick, thanks for posting that idea for the rest of us.
eserv
May 27, 2009
2,130
127
Hardisty, Alberta
Well I got the RTV900 back together and she works just fine! 6.5 hr's instead of 14 customer is happy and so am I!
Ed
