RTV900 Not Charging
Ryark Farms
RTV900
Apr 18, 2024
Bethany, WV
Replaced Battery
Replaced Battery Cables and cleaned ground area
replaced alternator
alt light on dash is good
found 15 amp fuse blown replaced blown again
Any information on THIS
Yotekiller
Sep 29, 2023
184
151
Southern Indiana
Replaced Battery
replaced alternator
The tail lights also run off that fuse. Check and make sure you don't have a damaged taillight or wiring to them.
2,180
You have a hot wire that is somehow "grounding" out.
Check for any wire damage via mice or other chaffed wires
4,083
1st thing to do... get the electrical wiring diagram in the WSM !!!
You can't properly, quickly troubleshoot without it.
2,180
Here is a piece of the circuit - hope it helps
Ryark Farms
RTV900
Apr 18, 2024
Bethany, WV
Thanks for the help. Yes, I pulled of the wiring schematics. Pulled all the conduit off found dirt and water. Cleaned, found moisture in the red and green stripped splices (2). Letting it dry over night, then use shrink insulation on the splices. Install new conduit and retape. Tested after cleaning all good.
4,083
Maybe be 'good' for now, but once water wicks it's way into stranded copper wire, it's only time before 'weird and random' problems rear their ugly heads.
