RTV 1140X Power steering issue
BuggyBeach
RTV 1140W
Jul 18, 2024
I have just started working for a mine underground and we use the 1140's as our utility vehicles to get around, i have one that's down with power steering issues. The hydraulic pump is good and the fluids, I have flow and pressure going to both fittings of the steering cylinder but it's not moving at all and it will not turn to the left. the wheel spins fine both ways and no weird noises coming from it. tie rods are attached. Thought I would see if anybody has had this problem before I pull the steering cylinder out
5,629
If you have pressure and flow to one line at a time you more than likely have a broken / blown cylinder.
whitetiger
Nov 20, 2011
2,730
1,228
Kansas City, KS
Remove the hoses from the steering cylinder and put a steel JIC plug at each hose's end. Start the engine and try to turn the steering wheel. It should feel like it did when fully turned to the steering stops.
That will confirm which has failed, the cylinder or the steering valve.
It is the cylinder probably 99% of the time.
BuggyBeach
RTV 1140W
Jul 18, 2024
Does that cylinder come out decently easily? do the tie rods have to come off or will it slide through the frame as a unit?
