Rod Bearings
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
89
29
Northern Idaho
So the rod bearings I ordered for my L2850 are way too small for my V-1702-DI engine. I’ve noticed that a lot of V-1702 aftermarket parts are made for V-1702-IDI engines (Bobcat) . Are IDI bearings smaller? Or is there an early/late difference?
8,189
Yes IDI bearings are smaller, the rod journals are smaller.
Bobcat used both the IDI and the DI engines so that can be confusing.
Do you need standard or oversized?
8,189
He you go:
Yes the bearings are the same as the 03 series of engines.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
89
29
Northern Idaho
Thanks again Wolfman! You’re a lifesaver! I’m under lot a pressure to get this thing running so we can use it to build my pole barn starting in a week or two.
