Reversing radiator fans
mikester
M59 TLB
Oct 21, 2017
3,515
1,975
www.divergentstuff.ca
Has anyone retrofitted their CUT with reversible fan blades? I'm thinking it would be nice to reverse direction on command to blow out the rad every once in a while like you can on the construction equipment.
4,818
Heck go all the way......ad a computer to the fan to control pitch based on engine load, outside air temperature, etc. !!! Turnbull would be happy.
jaxs
B1750HST
Jun 22, 2023
716
504
Won't work unless pitch of blades are changed at same time and pitch is often curved blade. Back to old school air compressor and water spray.
mikester
M59 TLB
Oct 21, 2017
3,515
1,975
My experience is to say no to water spray. Leaf blower has been working well for me lately and I like it better than the compressor.
It's been a dry fall this year and my screens are getting plugged fast
jaxs
B1750HST
Jun 22, 2023
716
504
If a leaf blower works for you I'd be the last to tell you to do anything different. I find leaf blower too bulky to get in position I need. I fabricated curved wands for air and water so that I can get the correct angle to fins.
3,298
Yep.. Water spray didn’t work too well for me when I was less-experienced with tractors…. I used the water hose to blow out the radiator on my 9N Ford. The cold water splashing on the square-ignition-coil cracked it.
It was a puzzle for awhile why it wouldn’t start even after drying things out.
jaxs
B1750HST
Jun 22, 2023
716
504
It's inadvisable to spray cold water on anything hot,esp cast iron and hard plastics . Countless manifolds have been cracked by rinsing immediately after using tractor. Regardless what is used to clear radiator, it should be directed in opposite direction of normal airflow (hence the reason op wants to reverse fan blades)
