Restoration of an RC48-G (with holes)
2,937
Good Lord it looks like you have cut away just about everything:eek:
5,391
I've see screen doors with less holes! :eek:
You've been using it to either mulch rice paddy's :p or you run a salt spray testing company, and this is your test piece!:rolleyes:
Oh and BTW good job, I'd be doing the same thing if it were mine!:D
300zx
Dec 1, 2010
445
Forest, VA
At least the spindle mounts are double plated and in good shape. This is a "new to me" G5200 whose deck had been neglected. It was full of wet debris under the belt covers. The spindles and gear box are in great shape. The idler pulley is stuck, so I will have to replace the bearing. This is for my Grandson who couldn't afford a new $2400 deck or even an $1800 skin, so Granddad gets to do some body work on it. I am trying to get it ready so he and his Dad can help me put it together over Thanksgiving. Most Fathers and Grandfathers know how these "labors of love" go!! I really enjoy restoring old iron.
John in VA
300zx
Dec 1, 2010
445
Forest, VA
Dam good idea with the paper templates.
Big Kahuna
Stole the idea from "tall" Ed China on Wheeler Dealers. It really works well. It is best to run it on the outside of any radius (rather than the inside and come up short). I bent the radius around a 1.25 in piece of solid shaft in my vice and then heated and bent it to fit after tacking the flat area. First timers luck, I guess!
John in VA
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
353
Homer City, Pa.
I'm doing a deck right now myself, RC60-71B, must have been the brothers to your deck, the end corner has issues and I just keep building the area up with fresh metal but it just don't look as good as your repairs.
Big Kahuna
300zx
Dec 1, 2010
445
Forest, VA
Big Kahuna
I found out today, that if you are not a good welder, you had better be a good grinder!! I probably ground off more weld than what is left. It was about the same as my dry wall mud ability!! My reel of 0.030 Mig wire ran out, so I grabbed another reel, put it on and started welding again. It didn't sound or look right. I checked the reel again and it was flux core! So I ground everything flat and will start again in the morning finishing the last piece I need to weld in, then pressure wash, dry and coat it with some rust neutralizer before I put the undercoat on it. I don't know if I will have it ready to put back together at Thanksgiving or not. Maybe I should shoot for Christmas!
John in VA
300zx
Dec 1, 2010
445
Forest, VA
Got the JASCO Prep and Primer for new and rusted metal on the deck and all its parts last night. Today, they all got Rustoleum Primer and 2 coats of Kubota's Bright Orange II. The surface looks "hammered" because of the rust pitting, but I have done all I can think of to stop the rust!! Another Kubota deck about ready to go back into service next Spring.
I think I will be ready Friday for my Grandson and his Dad to help put it back together. I was able to get the idler pulley bearings locally, so no waiting for parts. The last 6 pictures in the album are the progress last night and today.
https://picasaweb.google.com/110263893958737890068/KubotaG5200DeckRepair#
John in VA
Big Kahuna
Dec 23, 2011
353
Homer City, Pa.
You brought life back to an object that many people would have gave up on because of its condition, I just love what you did, you seen in your mind what it would end up as, you did a fantastic job and I'm proud of what you did, I just love orange tractors!
Big Kahuna
300zx
Dec 1, 2010
445
Forest, VA
Thanks guys. I really enjoy restoring old iron that was originally designed to have a long life. I am afraid not all equipment is made that way any more!
John in VA
300zx
Dec 1, 2010
445
Forest, VA
