I just replaced the head gasket on my Zen-Noh zl-1801-fd. I have drained and bled the injectors but cranking it over with the lines cracked at the injectors until I had a fair stream of fuel from the line. I then tightened the lines and it fires right up, except it smokes terrible black smoke with no power. If I try to bled the lines with it running, after I crak open the front injector line it tries to die, if I do the same to the rear line it will continue to run and allow me to purge the line.
Some thoughts.
The injector pump still has air. I do not know how to purge.
The injector(s) is\are dirty, Can I remove and clean with carburetor spray? Do I need to completely remove them?
Any and all information is appreciated.
Some thoughts.
