G garrettohio Member Equipment Kubota L2900 Sep 16, 2023 70 2 8 Ohio Aug 22, 2024 #1 How do you remove the front two middle oil pan bolts?.the piece that holds front axle is in the way.also can you use a bolt instead of the pin that holds driveshaft couplers.they don't give you much room to pound out the pins.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,727 5,930 113 Sandpoint, ID Aug 22, 2024 #2 You have to drop the axle. Not a good idea to change it out to a bolt. And clearance will be an issue. Reactions: 1 users
G garrettohio Member Equipment Kubota L2900 Sep 16, 2023 70 2 8 Ohio Aug 23, 2024 #3 T North Idaho Wolfman said: You have to drop the axle. Not a good idea to change it out to a bolt. And clearance will be an issue. Click to expand... Thanks for the advice.any advice on replacing front pinion gear couple slides on.mine is broke.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,727 5,930 113 Sandpoint, ID Aug 23, 2024 #4 garrettohio said: T Thanks for the advice.any advice on replacing front pinion gear couple slides on.mine is broke. Click to expand... Consult the WSM for repair info on that. Reactions: 1 user
G garrettohio Member Equipment Kubota L2900 Sep 16, 2023 70 2 8 Ohio Aug 24, 2024 #5 North Idaho Wolfman said: Consult the WSM for repair info on that. Click to expand... I looked at the manual.does the pinion gear come off shaft or one piece.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,727 5,930 113 Sandpoint, ID Aug 24, 2024 #6 It's one piece, you will need to get the ring too, they are a matched set.
