Removing the front two middle oil pan bolts on L2900 4x4
garrettohio
Kubota L2900
Sep 16, 2023
89
How do you remove the front two middle oil pan bolts?.the piece that holds front axle is in the way.also can you use a bolt instead of the pin that holds driveshaft couplers.they don't give you much room to pound out the pins.
6,132
You have to drop the axle.
Not a good idea to change it out to a bolt.
And clearance will be an issue.
6,132
It's one piece, you will need to get the ring too, they are a matched set.
