Looking for some help here. I had a very slow leak out of the rear PTO cover assembly. My plan was to remove the cover and redo the gasket on it. I removed the cover following the instructions here:
https://www.manualslib.com/manual/2033318/Kubota-Wsm-Bx1880.html?page=241
The problem I ran into was when I went to put the cover back on the 1T PTO select shaft is too far to the rear and for the life of me I can't get it to slide back in all the way. Is there a trick to this? Or did I mess something up? I really hope I don't have to pull apart more of the transmission to fix this.....
Thanks for the help!
