Removing and reinstalling Rim Guard Ballast in a tire.
3,920
I have some old tires that have Rim Guard installed in them. What would be the easiest way to remove it from the tire without ruining the tire? I would like to install the Rim Guard into some new tires, so what is the easiest method to get it into the new tire?
4,432
I think there is a special pump used to pump Rim Guard and that is why some dealers don't like to use it. Might inquire with a dealer and try to discover what they use, and then try to find something similar.
5,276
Your going to have to pump it out and then pump it back in.
And yes it takes a pump that will handle semi solids.
