Make sure you drain gear oil first. Some have plug on bottom others you will have to remove the whole top and extract the oil out. Depending if it’s the input or output seal? obviously makes a huge difference in what needs to be removed
If you doing both remove pto and then remove blades and blade carrier underneath, then the gearbox you can take to your bench to work on, much easier than trying to do the output shaft underneath the mower and safer too
