Rad Flush
AndyM
BX25DTLB
Sep 21, 2016
452
112
Vancouver Island Canada
Time to do a rad flush but getting to the drain plug seems darn near impossible. Any problem with undoing the lower rad hose instead? Or is there a trick to getting at that plug someone would like to share?
Pau7220
Aug 1, 2017
785
277
Scranton, PA
No problem at all using the lower hose(y)
BruceP
G5200H
Aug 7, 2016
844
363
Richmond, Vermont, USA
A couple tips when flushing cooling-system:
After gravity-draining is complete, use a leaf-blower to blow into top of radiator (where the cap usually goes) You will be amazed how much additional fluid comes out the drains.
Also a reminder - Unless your tap-water is unusually pure.... use ONLY distilled water to flush and mix with your antifreeze. Otherwise, the dissolved contaminants will precipitate out of suspension and form a coating inside your cooling-system which cannot be cleaned off. This coating reduces the effencincy of your cooling system (Kubota cooling systems are already weak with brand new shiney clean metal on the inside)
