Question about hydraulic hood on a BX2822 Snowblower.
4,891
The hood opening and closing on my snowblower moves too quickly and I want to install a restrictor in the line to slow the movement. It is operated by a 3rd function valve. The Parker 4A789A is an adjustable metered flow valvea indicated by an arrow on the side of the valve. Which way should the valve arrow be placed? My thoughts are that the cylinder being filled should have the arrow facing the cylinder and the other one should face away from the cylinder. Also, should I use brass or steel close nipples to make the connections? Presently I have 2 steel close nipples.
Kennyd4110
Vendor Member
Sep 7, 2013
1,239
444
Westminster, MD
www.boltonhooks.com
You would install them opposite to each other and adjust as needed.
Technically brass should not be used in hydraulic circuits because of the pressure, but the deflector is and low load device so you'll be OK.
5,060
Use whatever nipples are rated for 2,000 PSI !!!
Those devices reduce flow not pressure
WARNING !!! Just looked them up ,saw this...
These valves control flow in a pneumatic circuit by increasing or decreasing the volume that passes through a line. They reduce the speed at which an actuator performs and allow air to flow in one direction only, allowing for free flow in the other direction.
They are for air use NOT hydraulic oil.
This one, https://www.princessauto.com/en/adjustable-line-throttle-valves/product/PA1000000783?skuId=8322869
is $119 Canucks....
4,891
These are the exactly same ones that I used on a hydraulic motor that I have used to turn the chute on my BX22 long before Kubota started offering ways to turn the chute from inside of the cab. I doubt that the piston is going to know the difference.
Product Details
Catalog Page2358
BrandPARKER
Manufacturer Part NumberF800B
SeriesF
Valve TypeControl
Maximum Pressure2,000 psi
Maximum Flow Rate15 gpm
Inlet Connection1/2 in NPT
Inlet Connection GenderFemale
Outlet Connection1/2 in NPT
Outlet Connection GenderFemale
Adjustment MethodRotary Knob
Actuation MechanismManual
Valve ControlFlow Control
Control DirectionOne-Way
Cracking Pressure5 psi
Overall Length3.44 in
Overall Height3.33 in
Overall Width1.25 in
Port-to-Port Length2.23 in
Body MaterialBrass
Includes SealsSeals Included
Seal MaterialNitrile
MountingInline
Coefficient of Volume (Cv)0.976
Operating Temperature - Maximum250 °F
Operating Temperature - Minimum-40 °F
Fluid ServiceOil
UNSPSC40141609
Country of Origin USA (subject to change)
Product Description
General purpose flow control valves regulate fluid flow rates in one direction and are free-flowing in the opposite direction.
5,060
love the internet..... one site says air ( the 1st one) , another says 'hydraulic', 3rd says parker no longer makes them,4th has them for $35 CDN........
What DR posts isn't the specs for the 4A789A unit. it's 1/4" NPT, not 1/2"
Dustball
2016 B2650HSDC
Sep 15, 2023
313
189
Hudson, WI
To simplify things since this is a chute deflector and there's not going to be much difference between extend and retract speeds and there's very little load, go with a single needle valve plumbed into one of the hoses.
With a needle valve, you only need one and it'll meter the flow in both directions with nearly the same speed. The difference in speed is due to the difference in volume of the cylinder on the rod side of the piston vs non-rod side.
With the directional flow control in the first post- two will be needed (one per hose) and you'd want to meter the flow exiting the cylinder (known as meter-out).
BAP
Dec 31, 2012
2,787
897
Unless you already own metered flow valves, restrictor fittings like those sold by Kennyd4110 are way more cheaper and just as effective.
WI_Hedgehog
BX2370 (impliment details in Profile-About)
Apr 24, 2024
364
383
Milwaukee, Wisconsin, U.S.A.
Same valve, lower cost:
Would this be a better option:
