Blue2Orange
For all you other newbies to quick hitches. Was having some issues detaching implements with the quick hitch. New BX. New to quick hitches. Didn't realize the top hook on the QH was binding a bit on the top connector bushing. Initially the box scraper was set up properly by the dealer to drop off. I adjusted the pitch to make it level relative to the tractor. When trying to detach it the 3Pt would not drop off as normal. Gave it a bit of a giggle like I needed to do with the snowblower. No go. Shut down the tractor and scratched my brain???? Next day taking a look I noticed the bushing was tight against the face of the back of the hook. Changed the top link length to "center". 3pt dropped.
Ignorance on my part. Thought once the QH was set it was set for all implements to engage and disengage without any further tuning. Hindsight that makes no sense. QH still beats conventional attaching. Happy I spent the extra couple hundred on the unit. Unfortunately the used LandPride RB05 is not QH compatible unless I can find about a total of 6" additional lower pin length.
