Hi guys
Was not sure what forum to put this in but as I have an L1-22DT (similar to L2250 & L2950) I thought I would put it in the grey section.
My tractor is 4WD and I would like to know the best setting to have the PTO at , and the tractor at, when running my slasher. The slasher will be used to clean up horse paddocks. The grass is not that long. It's just that when you let it get to a foot or more the weeds start showing through.
There are 4 gears to the PTO and the guy I bought the tractor from said he always ran the PTO in second gear.
As well as the gear tho, what should I have the Revs at? (Using the rev lever on the column)
And should I be running the tractor in 1st gear when running the slasher?
I know there is MidPTO but I have even less idea what that's about or what I would need that for. All the decals are either in Japanese or worn away altogether.
