PTO indicator on. Will not start
Dtmedcare
Kubota L3240hst
May 1, 2025
Louisiana
L3240 will not start. PTO dash indicator is on but PTO switch is off. When problem first appeared, tractor was running, but would die if HST pedal was depressed.
Help! How do I troubleshoot?
8,212
Look at the mid PTO too.
Need to know if it's a L3240 or a L3240-3 or a cabbed model of either.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,015
830
canada
Is it the pto indicator or the brake indicator. The park brake being on, will kill the engine as some as you move the treadle.
Dtmedcare
Kubota L3240hst
May 1, 2025
Louisiana
Thanks so much for the advice.
After several suggestions to check fuses, I decided to recheck them. Sure enough, I found the culprit. Unsure as to how I missed the bad one when initially checked, but.......
Thanks Again
