Post Hole attachment for BX25D
stevewhitts
BX25D
Mar 5, 2025
Maryland
I'm looking at the TS Country Pro 18-100 HP 3-Point Post Hole Digger for my BX25D. I don't have a ton of posts to do, but having something available when needed would be great. Are there better options out there or are they all mostly the same?
jyoutz
Jan 14, 2019
3,278
2,301
Edgewood, New Mexico
Can a BX lift a post hike digger high enough to clear the ground? IDK. Just asking.
8,033
Good question, will need to look into. That would be a PIA if it can't.
Compare specs to the Land pride PH digger that meets the specs for the BX.
Most of the Full size PH diggers can not be lifted high enough to clear the ground.
5,499
clearing is one thing....
hmm... how DEEP must you dig !!! Around me 3 1/2 feet is 'frost', which of course varies nbased on where you live.
Doesn't make any sense to buy a 3' digger when you have to go 4' down.
Don't think my BX23S will lift a 4' unit.
other options, instead of buying is to
rent a proper machine or hire it out.
either way when you plan the job ahead, be prepared, it'll go faster, smoother, might save money too.
I've past up PHDs in the past, cheaper to hire it out. NO stones so guys can drill fast.
