Overfilled engine oil on BX23
pjoh784350
BX23, quick attach bucket, 3 point, pallet forks
May 3, 2019
167
74
Danville
Looks like I may have about half a quart extra oil in the BX23. Should I be worried? How much overfull is too much overfull?
2,737
Overfilled can be worse than underfilled!
Over full is BAD simply because the moving parts will whip the oil - and place a zillion air bubbles in it! And we all know air is not a good lubricate!
Get under and pull plug and remove a good bit - more than you need, tighten plug and if you wish - add the oil back to the upper mark.
Now IF you have a large syringe laying around and some small tubing - you can suck out a bit via the dipstick passage. Most of us are forced to do this on water craft since the plug would make a hellva mess in the boat.
pjoh784350
May 3, 2019
167
74
Danville
THanks..
