Oil Service on M6-111
Grampy5
M6-111, ZD331, SVL90
May 24, 2024
Oklahoma
Am i correct in assuming on my recently acquired used M6-111, the transmission oil, power steering, hydraulic fluid is all in one. So front 4wd is separate, engine oil is separate, correct ? Just wanting to do a complete service, just double checking. Thanks in advance.
Mitjam
M-108, M6-111, Lx3520. Landpride RCR1272,RB1684,SPL1072,FDR1672, westward tiller
Jan 14, 2013
51
26
Edmonton, Alberta, Canada
Yes that’s correct, depending if someone changed front axle oil if it’s original oil everything but engine oil will be Kubota UDT.
Grampy5
May 24, 2024
Oklahoma
Thank you. I couldn't find it in the owners manuel or the interweb and of course the dealer wants me to bring it in. I just wanted to verify. Thank you again.
5,480
Get the WSM (aka service manual) so you know where all the drains are located, there is more than one.
whitetiger
Nov 20, 2011
2,678
1,180
Kansas City, KS
DO NOT PUT UDT IN THE ENGINE!!!!!!!!!!!!!
The engine requires engine oil.
The front axle requires UDT, SUDT2, or 80/90.
The transmission-rear axle-power steering-hydraulic oil requires UDT or preferably SUDT2.
BAP
Dec 31, 2012
2,579
709
Reread your owners manual. Kubota does do a pretty decent job with pictures and arrows pointing to the drain plugs, dipstick and fill points for the various fluids. Also they have charts that tell fluid types used and quantities plus the service intervals.
