oil pressure sending switch location
jsr12839
ny
Hi I have an l2250 disel 4w drive. Low oil pressure light comes on. need to know where to find oil pressure switch and how much oil pressure should i have. I appreciate any other info that you could pass on.
jim:(:confused:
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,115
Hardisty, Alberta
Hi JSR
your oil pressure switch is on the left hand side near the back of the engine just below the cylinder head. Pressure switch should operate at 7 psi. system relief is 64 psi. Kubota haven't given a spec on it but I would say minimum oil pressure, hot engine at idle should be no less than 10 psi.
Ed
