One of my best friends (after all, he sold me my Kubota
) has purchased a poor substitute for the Kubota, a Yanmar 1500. It had a couple of missing bearings & broken gears in the left 4wd knuckle, and he thinks he has all the parts needed on order to put it back together. Now for the question:
There are two bevel gears with roller bearings in their bores that slide over a spindle. Above & below this assembly are two washers with oil grooves in them- he thinks the grooves should face away from the bearings, and I say towards them.... the rollers bearings don't bear on the washers, the washers simply locate the assembly on the spindle. When he took it apart, it was so filthy he didn't notice the grooves until he cleaned the parts. Service manual is no help, nor the parts manual, or the dealer. (it's a grey model) I think the grooves will allow oil to get to the roller bearings, he thinks the bearings need the support of the un-grooved side. (again, the rollers never touch the washers)
1st pic shows the type of washer, 2nd is the exploded view, with parts #49 & #52 being the washers in question.
Help please....
Help please....
