Non stick coating for mower deck
dlundblad
G5200, L2501, ZD1211
May 16, 2009
503
10
IN
Anyone have any suggestions for a non stick coating to apply to the underneath side of a mower deck to prevent and/ or easily remove sticking grass?
Thanks.
2,240
Pam, as used in cooking.
I second that. I save all the wife's cooking sprays when they go out of date.
Works pretty well as a release agent in clay/sticky soils on backhoe & FEL buckets too.
4,105
I think some use Fluid Film.
I haven't yet, but might try it sometime.
Fido Farms
L3901, 35 Massey, Summit X 146, Polaris 700 RMK, Yamaha Viking
May 27, 2018
112
I clean it our after every cut and it cleans easily. If u leave it for a while it ain't fun to scrape off.
nbryan
Jan 3, 2019
1,169
711
Hadashville, Manitoba, Canada
Thanks.
The only thing that I know that doesn't let anything stick to it is Teflon. Teflon painting is a multistage process starting with sandblasting and finishing with baking on the final coat. I'm sure very expensive!
Sent from my Moto G (5) Plus using Tapatalk
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
328
89
Ottawa, ontario
I have used por15 paint for many different uses. Painted the inside of my 3 point finish mower and grass sticking issue has been reduced.
Alderman
42
I tried something called Mo-cote.
I clean the deck after every use so I can’t say it made any improvement.
4,432
There is a product called "Slip Plate" made for keeping the plow shears from rusting. But it down't stay on very long when the plow is back in the soil. Fluid Film would work, it's just too expensive for that purpose, since it also will be quickly wore off.
There is nothing I am aware of that will stay on for many hours of mowing. Probably have to clean the mower frequently, or mow when the grass is dry.
SidecarFlip
Banned
548
Thats me. Mowing 7 acres, nothing stays on the deck for long. I just pressure wash mine regularly. Usually, I'll pressure wash it and then grease the spindles to force any water out of the bearings.
hockeystewey
2017 BX1880 w FEL, 54"MMM, 2019 BX2816 50 " snowblower
Dec 12, 2017
114
NY
I use Fluid Film on my mower deck....works like a champ....I respray it a few times a season, whenever I drop the deck to sharpen the blades.
Yooper
3901 LA525
May 31, 2015
1,464
433
NE Wisconsin
If you could find a coating that would hold up to the 'sandblasting effect' that goes on under a mower deck, you will have discovered the Holy Grail of lawn mowers.
4,105
Like ‘Cat points out, Fluid Film is ~$10 for a can.
But I found out the hard way a little goes a long way....had it slobbered all over my cast table saw...[emoji15]
I still have third of a can left after 3 years. It’s good stuff in my book, just use it sparingly. [emoji2957]
dlundblad
May 16, 2009
503
10
IN
I’ve thought about adding POR15 to the G5200’s deck. Seems to be good stuff if used correctly with their 3 step process.. No idea on the non stick, but I can report back if I use it if anyone is interested.
The non stick stuff would be for my new LP finisher.
mikester
M59 TLB
Oct 21, 2017
3,169
1,652
www.divergentstuff.ca
Avoiding wet grass goes a long way. I find that long wet grass sticks to the deck more too. When the mower starts streaking or leaving clumps it’s time to scrape the deck.
FYI I bought a cheapo pneumatic paint scraper with a 2 inch wide chisel. It does a really good job scraping the deck and helps me avoid skinned knuckles. Much easier than hand scraping and less messy than the pressure washer.
2,867
Good Lord now I feel like a slob now washing the deck after each use :rolleyes:.. Yeah like thats gona happen :D
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,140
938
Williamstown Ontario Canada
