No regen yet
Peeps
L3902
May 17, 2024
Wisconsin
I bought a new L3902 this summer and now have 47 hours on it. It’s been used for a lot of grapple work running at 2100 rpms and some stump grinding at pto speed. Most of the time I run it for hours and the weather has been hot during use. I haven’t had a regen yet. Should I be concerned about that?
Bmyers
May 27, 2019
3,269
3,820
Southern Illinois
Nope.
The higher RPMs and PTO RPMS (which are higher) you most likely are keeping everything burnt off or adding minimal amount.
Cold weather, you have idle time to let the tractor warm up, you may not be using the PTO as much, so the DPF will get clogged sooner due to less heat.
So far this summer, I have regenned one time. Winter time, I regen more often.
4,040
No - thats about how my L3901 behaves in that usage. I would be expecting one soon.
MotoBBQ
L3902 w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
51
MN
56hrs on my L3902, same type of use. No regens yet. I'm expecting around 75hrs from what I've read on here.
jyoutz
Jan 14, 2019
2,816
1,871
Edgewood, New Mexico
The first regen on my tractor was at around 70 hours.
