Newbie with BX2680 Hydraulic Control Lever question
Dannymax
Kubota BX2680, RCK60B23BX60, Kubota LA344 FEL, 3 pt log arm with lifting tongs,
Sep 22, 2023
19
11
Columbia Co. NY
When using the Hydraulic Control Lever to raise/lower the mid mount mowing deck the 3 point hitch moves up and down with the mower deck. Is this normal or is there a lock out to keep the 3 pt hitch stationary?
4,160
The mid mount mower is raised by/ connected to the 3 Point Hitch mechanism.
If the 3 point hitch doesn’t go up/down neither does the mower.
Dannymax
Sep 22, 2023
19
11
Columbia Co. NY
Guess it's working as it should. Thanks for the reply.
WillyY
BX2680
Feb 11, 2024
Columbus Ms
I had the same problem using my three point hitch for my sprayer. (I spray fire lanes and require the mower to be all the way up. When I did, the sprayer would run into the back of the seat as well as my sun over attached to the roll bar!) Ultimately I was able to use the additional holes on the tractor 3 point system to mount it so that it would not move up/down with the mower deck. Hope this might help you.
Bearcatrp
BX1880
Mar 28, 2023
421
212
Minnesota
Have found not to push the lever all the way to keep the 3 point from moving when moving the mower deck. Would be nice if there was a way to lock the 3 point in top position like there is one for the deck.
